1998 Saturn SL2 hard starting
180,500 MILES • 4 CYL • 2WD • MANUAL
BONES1966
the car acted like it was flooded and after pumping the pedal then holding it down it would start then one day of this the wires to the starter started to smoke then nothing the starter didn't even click
Aug 3, 2010 at 9:45 AM
SATURNTECH9
  • 30,868 POSTS
Sounds like you have two problems so what wire's started smoking?
Aug 3, 2010 at 9:59 AM
BONES1966
there was (that looked like to me) 2 small gauge wires that led to the starter that started to smoke. I dont think it was the ground wire
Aug 3, 2010 at 10:12 AM
SATURNTECH9
  • 30,868 POSTS
There's a purple trigger wire to the solenoid on the starter.I would take the starter out and have it tested most likely it's the starter smoking the wire.
Aug 3, 2010 at 10:52 AM
