1998 Saturn SL2 DTC code P0401
PELAID1
Engine Performance problem
1998 Saturn SL2 4 cyl Front Wheel Drive Automatic
Got the code P0401, which is for EGR insufficient flow. Rreplaced the EGR valve, cleared the code, but it keeps coming back (tried three times). What other than the EGR valve could cause this code?
Aug 13, 2009 at 3:02 PM
BLUELIGHTNIN6
  • 16,542 POSTS
carbon build-up in passageway to EGR valve may restrict exhaust gas flow causing this code to appear.
Aug 13, 2009 at 5:42 PM
SATURNSERVICEMANAGER
  • 10 POSTS
we often find that other things may cause this code -
you may want to check the engine temperature sensor and its connector (corrosion) - it may read incorrectly causing the computer to think the egr valve is not performing correctly - check/clean the ground bolts on the coil for corrosion also
Aug 20, 2009 at 2:01 PM
