1998 Saturn SL2 cruise control
PETTA24
Engine Performance problem
1998 Saturn SL2 4 cyl Front Wheel Drive Automatic
recently my car stalled for the first time while i was inline at a drive through. it took three cranks but eventually it started thank god, now the vehicle seems to be driving like it is cruise control. i take my foot of the gas and and continues to accelarate and takes a long time to deaccelerate. also when i apply the break it revs up to 2 on the rpm meter, just seems like the engine is getting gas when im not applying it, also i might me paranoid but it looks like there is gas leaking from under my car i noticed in the parking lot this mornig, any suggestions, like maybe fuel pump or 02 sensor or something
Jan 22, 2009 at 8:37 AM
KEVIN12881
  • 336 POSTS
sounds like a throttle control sensor. you can put some card board under the car to better see what it leaks overnight. donate for a pro to help, a few bucks will do. You RPM problem could be a number of thins, but I doubt it has anything to do with the cruise control. you can take the cruise control fuse out if it makes you feel better
Jan 22, 2009 at 8:52 AM
