1998 Saturn SL2 Brake Shoe Springs
140,000 MILES • 4 CYL • FWD • AUTOMATIC
JKGLADDEN
How oftern if ever should brake shoe springs be replaced?
Mar 21, 2010 at 6:33 AM
SATURNTECH9
  • 30,869 POSTS
depends on ur weather if u have alot of snow and they salt it down and it gets in ur rear brakes then i would change them.but if u have nice dry weather like california then i would just replace the shoes and inspect the springs and hardware kit and when in doubt just change them there pretty cheap.make sure u check ur rear wheel cylinders they leak often on that yr range u have.pull back the rear dust boot cover if fluid comes out change both of them.if u change them make sure u get four new copper crush washers for the brake lines or u will have brake fluid leaking out.let me know how it goes.
Mar 21, 2010 at 7:15 AM
