1998 Saturn SL2 1.9 liter knock
11,900 MILES • 4 CYL • FWD • AUTOMATIC
PEARCESHOP
I noticed a posting on the 1.9 liter knock. My car is doing the same thing. I wonder if it is in the timing chain. It seems to speed up and slow down when cranking the engine. Just before the battery dies, it will run only for a few seconds. It does sound like the knock is in the top end, and the exhaust at the same time. Do you know what causes this before I start teardown? The previous owner thinks it is a lifter. I know that would be hard since it is overhead cam! It has occurred to me, though, that it cuold be in a valve or cam follower in order to hear it in the exhaust. Please help, Joe
Mar 14, 2010 at 9:56 AM
MMPRINCE4000
  • 8,548 POSTS
Knocks are usually rod or main bearings, could be a tooth missing on camshaft cog.
I would inspect the chain first, then camshaft lobes and lifters.
Mar 15, 2010 at 1:31 AM
