1998 Saturn SL2
JOYCE KASHE
Engine Performance problem
1998 Saturn SL2 107,00 miles
The car feels like it will not go into gear -- it "jumps."
I have had it in for repair for this from both the Saturn dealer (5 years ago) and a couple of mechanics. No one can seem to find a problem. I am afraid the car is just going to stop -- is this possible?
The coolant light went on but when I took it in for repair, the mechanic said nothing was wrong. He topped off the coolant.
May 16, 2010 at 3:15 AM
SATURNTECH9
  • 30,868 POSTS
[quote:e382c0600c="Joyce Kashe"]Engine Performance problem
The coolant light went on but when I took it in for repair, the mechanic said nothing was wrong. He topped off the coolant.[/quote:e382c0600c]as far as the transmission goes are you saying it shifts hard into gear if so which gears?do you have any trouble codes?as far as your low coolant you could have a leak or a bad coolant cap.keep an eye on the coolant level if the light comes on again i would just replace the cap there only like 6.also look at your radiator tank right below where your upper hose goes on its common for them to crack and leak there.also the water pump is another common place to leak.let me know what you find.
May 17, 2010 at 8:21 AM
