1998 Saturn SL2
HISBABYGURL2010
  • 1998 SATURN SL2
Engine Mechanical problem
1998 Saturn SL2 4 cyl Front Wheel Drive Automatic
my engine cranks over but it acts like its not gettin a spark
Friday, March 19th, 2010 AT 10:31 PM
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Friday, March 19th, 2010 AT 10:45 PM
