1997 Saturn SL2 4 cyl Front Wheel Drive Automatic
PUT ENGINE AND TRANS FROM WRECKING YARD WITH 76000 MILES IN CAR. CANT GET TRANSMISSION TO BACK UP. FORWARD GEARS SEAM TO WORK OK, MAYBE A LITTLE SPONGE ON SHIFTS. DTC CODE IS PO732 [GEAR 2 RATIO INCORRECT]. TRANS WILL BACK UP ON FLAT GROUND SLOWLY IF YOU REV ENGINE. THE NEWER ENGINE /TRANS ARE ALSO 1997 COULD THIS BE A SENSOR OR WIRING PROBLEM OR IS IT AN INTERNAL DEFECT
updated 3/9/09
car pros the info you gave me was correct but a little incomplete. Here is the fix I got from the wrecking yard the engine/trans was purchased from. Remve rear cover of trans, nut on clutch pack on back of transmision was loose remove nut completely [23 mm 12point thin wall socket] clean shaft and nut threads apply red loctite retorqe nut to 111ft lbs
silicone gskt maker can be used for cover gasket but there are oil passages that could get blocked . If possible I would get new gasket and lock nut from saturn, this job can be done wile in vehicle but you mus remove 2 bolts on trans mount an lower about 3/8 inch to clear unibody frame also remove lower ball joint and pull hub to rear of car. Apparently this is a fairly common problem with with these cars hope this helps.
SPONSORED LINKS
Friday, March 6th, 2009 AT 12:44 PM
