My car starts sometimes when I turn the key, usually when it's warm, but not always, sometimes very cold. All of the dash lights come on and sometimes it will crank, other times nothing. I pulled the starter and it checked out good. The battery is nearly new, and I've replaced the ignitionn switch and key cylinder. I've been trying to locate the clutch switch, which I don't see at the top of the clutch pedal, where the Haynes manuel says it is, but will check that when I find it.
The car doesn't stop running after it's started and always starts when roll/push started.
Any suggestions or known inherent problems with this?
Jan 25, 2010 at 2:38 PM
