1997 Saturn SL2 service light is on
1997 SATURN SL2
ELOHNIL
Electrical problem
1997 Saturn SL2 4 cyl Two Wheel Drive Manual
I have a 1997 Saturn SL2 with manual tran. The service light is on (with wrench picture) after I drove it for 2miles. How do I reset this light or what can I do to correct the problem? The engine runs smooth & I check everything but nothing appear to be wrong, what cause this "service (with wrench picture)" turn on?
Jun 7, 2010 at 1:13 PM
SATURNTECH9
  • 30,869 POSTS
[quote:e970450272="elohnil"]Electrical problem
I have a 1997 Saturn SL2 with manual tran. The service light is on (with wrench picture) after I drove it for 2miles. How do I reset this light or what can I do to correct the problem? The engine runs smooth & I check everything but nothing appear to be wrong, what cause this "service (with wrench picture)" turn on?[/quote:e970450272]
First of all thank you so much for your donation.As far as what can cause your wrench light to come on is a lot of thing's.What i need you to do is go to a auto part's store like auto zone and get your codes scanned and bring me back the code number's so i can help you with that.To shut the light off there scanner can do that too.But when the failure happens the light will come back on.Let me know what code numbers you have.
Jun 7, 2010 at 1:43 PM
