1997 Saturn SL2 rotor & drum discard thicknesses
90,000 MILES • 4 CYL • 2WD • AUTOMATIC
SWERVIN
Can you please tell me the minimum discard thicknesses for the drums and rotors? I'm getting them resurfaced at Checkers; however they said that they may need to be replaced once they get them measured... I just want to make sure everyone's being honest.... Thanks!
Swerv
Mar 9, 2010 at 4:31 AM
SATURNTECH9
  • 30,869 POSTS
[quote:88d794fd6c="Swervin"]Brakes problem
1997 Saturn SL2 4 cyl Two Wheel Drive Automatic 90000 miles
Swerv[/quote:88d794fd6c]
front rotors are min refinshed thickness is 16.1mm and th rear drum maximum refinshed diameter is 200.6mm.
Mar 9, 2010 at 5:30 AM
SWERVIN
[quote:a202aaa912="saturntech9"][quote:a202aaa912="Swervin"]Brakes problem
Swerv[/quote:a202aaa912]
front rotors are min refinshed thickness is 16.1mm and th rear drum maximum refinshed diameter is 200.6mm.[/quote:a202aaa912]
Thanks Louie!! Thanks for your answer!
I would donate; however at the moment I'm pretty broke..... Next time
Thanks Again,
Swerv
Mar 9, 2010 at 5:58 AM
