1997 Saturn SL2 need help
HOUSE42
Engine Performance problem
1997 Saturn SL2 4 cyl Two Wheel Drive Automatic
the crank censor, the car will start when it is cool. but after a couple miles, turn the car off . start it and all it does is crank.. sometimes it does not even crank.
Dec 28, 2009 at 10:04 AM
  • 75,988 POSTS
Cranks and w/n start
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
No crank at all/nothing/nada:
Could be the starter, starter relay, park and neutral switch and ignition switch assuming the battery and connections are good.
Dec 28, 2009 at 9:09 PM
