1997 Saturn SL2 Emissions
113,000 MILES • 4 CYL • FWD • MANUAL
BRADLUNT
My car is a 1997 SL2, and it idles high, about 1200-1300 RPM's and when the car is given a slight amount of gas, the car almost dies, then catches itself and goes back to a high idle. I have purchased a TPS for the car, but not installed, I have also changed out the EGR Valve, the plugs and wires. When the car does die, it acts as if it is flooded emitting black smoke, when the peddle is held to the floor the car starts up. Any ideas please, I need to get my car past it's emissions test.
Aug 14, 2009 at 6:43 PM
  • 75,988 POSTS
Clean out the idle air control valve and check the TPS also check the fuel pressure.
Aug 14, 2009 at 8:44 PM
