1997 Saturn SL2 Cooling Fan
160,000 MILES • 4 CYL • FWD • AUTOMATIC
FUDZ073
My '97 Saturn SL2 has been overheating lately. I checked the coolant levels and they seem to be fine. I then looked the cooling fan. It doesn't want to turn on. I checked the fan motor and the fuse box. The motor works and all the fuses are intact. I am convinced the radiator is not clogged since the car doesn't overheat when it's moving. What could be the problem?
Jan 14, 2010 at 6:18 AM
SATURNTECH9
  • 30,869 POSTS
how high does the temp gauge go up too when its overheating?also u said the fan doesnt work but then u said u checked it and it work does the engine cooling fan come on when u turn the a/c on?
Jan 12, 2019 at 4:26 AM
