1997 Saturn SL2 check engine light
146,572 MILES • 4 CYL • FWD • AUTOMATIC
YOATA MAN
i had car put on diganostic and egr or erg valve was bad so it was replaced and i want to reset the check engine light i replaced the part but light wont go off would like to know how to get the light off
Apr 27, 2009 at 8:28 AM
OBXAUTOMEDIC
  • 3,719 POSTS
[quote:0ffd65f580="yoata man"]Electrical problem
1997 Saturn SL2 4 cyl Front Wheel Drive Automatic 146572 miles
i had car put on diganostic and egr or erg valve was bad so it was replaced and i want to reset the check engine light i replaced the part but light wont go off would like to know how to get the light off[/quote:0ffd65f580]
Go by your local parts store and see if they will turn it off for you. They will have to use there OBD2 Scanner to reset light.
Otherwise it will turn itself off after 500 - 1000 miles or 50 - 100 key starts.
Apr 27, 2009 at 8:33 AM
