1997 Saturn SL2 car cuts off
IMSMOKEY
  • 1997 SATURN SL2
  • 4 CYL
  • FWD
  • 170,254 MILES
I have this car I have replacest trans temp senser, throttle senser, idler senser, pvc valve and egr to put when the car get to normal driving temp it starts jurking on tack off and some times cut off but if a/c is on and u dirve up and stop at a light and u ant holding the brake an gas the car will cut off and this is and automatice tran car what is rong with it this is the only car me and my wife an son have we need help thank u.
Saturday, May 15th, 2010 AT 11:22 AM
SATURNTECH9
  • 30,869 POSTS
Have u change the coolant temp sensor yet if u replace it make sure u get a brass tipped one not a plastic tipped one those crack and inspected the connector if the connector is corroded then u will have to replace the connector too. The sensor is like 10 they cause the cars to do crazy stuff. Also inspect the spark plug wires for carbon where the spark plugs meet the plugs and inspect the spark plugs for black carbon and spark plug tips for being worn. Also inspect the coil towers for corrossion. If u change the spark plugs just use standard ngks no platnuims they carbon fowl in ur car. Let me know what u find.
Saturday, May 15th, 2010 AT 12:07 PM
