Friday, October 10th, 2008 AT 8:02 PM
I've been having problems with my Saturn as of late. The car would start fine then as soon as the rpms went down after the initial crank the car will just shut off. Then the car won't start again but if you keep trying it will eventually turn over after a while. Then when you take the car out of park and into drive the car will try to stall out. If it doesn't stall out and you get going it seems to run ok. Especially once the car warms up. Then when I get home from where I'm coming from and try to shut it off and start it again it will start no problem. Also note that I've changed the spark plugs and the plug wires recently. Thanks in advance for your feedback!
