1996 Saturn SL2 ignition cylinder lock
148,000 MILES • 4 CYL • FWD • AUTOMATIC
GREG BROWN
my problem started when my key would not turn the key lock cylinder, I could not turn it to the run position to be able to pull it out, I was advised by a guy at the parts store to drill it out, so that is what I did, in the process I went to far and drilled the stub that th key lock cylinder fits over. any sugestions? also what wuold the parf that I drilled into by mistake be called
Feb 14, 2010 at 2:58 AM
SATURNTECH9
  • 30,869 POSTS
[quote:841648297f="greg brown"]Electrical problem
1996 Saturn SL2 4 cyl Front Wheel Drive Automatic 148000 miles
my problem started when my key would not turn the key lock cylinder, I could not turn it to the run position to be able to pull it out, I was advised by a guy at the parts store to drill it out, so that is what I did, in the process I went to far and drilled the stub that th key lock cylinder fits over. any sugestions? also what wuold the parf that I drilled into by mistake be called[/quote:841648297f]
there's the cyclinder it fits into a sleeve they both come together when u buy them.then that goes into the housing.can u turn the cyclinder to the acc postion if u can then we might be able to remove the cyclinder.let me know.
Feb 14, 2010 at 3:41 AM
