HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Saturn
SL2
Engine
Symptoms
Idle High
1996 Saturn SL2 Idiling high
FWTNYE
MEMBER
1996 SATURN SL2
1996 Saturn SL2 4 cyl 89000 miles
Just recently my car has been idiling high, both in neutral and when shifting gears. What could be the problem?
Tuesday, October 21st, 2008 AT 12:53 AM
MECHANIC
Hi fwtnye and welcome to 2carpros
shifting gears. Is it a manual transmission? Clutch could be slipping.
Also go head and check the idle air control valve and throttle position sensor-
Good Luck
Tuesday, October 21st, 2008 AT 3:50 AM
Please
login
or
register
to post a reply.
Related Engine Idle High Content
Engine Runs Cool Going Down The Road But Heats Up...
If I'm Going Down The Road The Temp Gauge Drops Down Just Above The First Mark, But If I Sit For A Period Of Time Idling It Warms Up To The...
Asked by
Droid0789
1996
SATURN SL2
Please Help
I Have A 96 Saturn Sl2 And Its Starting To Misfire (sometimes) And Its Starting To Smoke And Has Recently Having High Idle And I Dont Want...
Asked by
Courtney Miller
1996
SATURN SL2
95 Saturn Sl2 High Idle/stalling Problems
Hi, I Have A 95 Saturn Sl-2 That Has Been Having Idle Problems And Stalling. The Idle Will Rise To 2000 Rpms Or So When I Start It Then...
Asked by
vegasbj247
2 IMAGES
1995
SATURN SL2
1995 Saturn Sl2 95 Saturn Sl2 High Idle
Hey Guys, I've Read A Lot Of Posts About This Problem, And Have Been Chasing It Around My Car Looking For A Solution. I Have A 1995...
Asked by
95saturnsl2
1995
SATURN SL2
High Idle
When Started Maintains 1900 Rpm When Driving And To A Stop. After About 20 Minutes Or More It Comes Back Down I Took It To Dealers They...
Asked by
albertamabisca
2 IMAGES
1998
SATURN SL2
VIEW MORE
Vacuum Leak Test and Repair
Vacuum Leak
Vacuum Leak Symptoms
