1996 Saturn SL2 Engine cooling Light
62,000 MILES • 4 CYL • FWD • MANUAL
TNTSHANNON
THe engine cooling light blinks indicating low coolant. Coolant level is fine. Temp gauge is fine and cooling fan cycles fine
any thoughts?
Jun 12, 2010 at 7:55 AM
SATURNTECH9
  • 30,868 POSTS
First make sure your coolant bottle is full to the seam of the bottle don't pay attenion to the fill Line you want to have it full to the seam.If the light is still on after that then check and make sure the back up fuse isn't blown in the under hood fuse box.If that is good then unplug the connector on the bottom of the collant bottle then make a jumper between the two terminal's and leave the jumper in place.If the light goes out then you have a bad coolant level sensor.But give it time for the light to go out with the jumper in place.Let me know what you find.
Jun 12, 2010 at 9:53 AM
