cooling fan not working?
250,000 MILES • 4 CYL • FWD • AUTOMATIC
HOLLY1058
I installed a new fan motor and it still does not come on
Mar 25, 2010 at 8:02 AM
SQM
  • 6,383 POSTS
Since you have already replaced the motor. You could have a faulty fan relay or defective wiring.
First you want to check the relay. The relay is located under the hood in the battery junction box (see diagram below).
Here is a article on how to test the relay:
Then you want to check to see if you are getting power to the fan.
I have attached diagnostics as well as wiring diagrams for your reference.
Aug 2, 2021 at 2:05 PM
