1996 Saturn SL2 Coolant Fan Electrical
769,000 MILES • 4 CYL • 2WD • MANUAL
BROKENBEAUTY19
Hello! I have a 1996 saturn sl DOHC that has been nothing but trouble, i had let my friend drive it once and he said that it overheated and wouldnt start back up after he put water in the radiator. When i got to where he had left my car i noticed that there was engine oil all over the engine, and strangely enough a hole in the radiator cap, which made no sense because there wasnt any radiator fluid on the engine. I later realized that the head gasket had a tiny hairline crack and my dad tried j/b welding it, but all that did was add to the mess in a way. now come to find my engine is still leaking, and the radiator fan wont turn on by itself i have to turn it on manually everytime before i drive it. i bought a sensor and a relay but even after replacing those the fan still isnt working. so basically my question is how do i rewire the connection to fan so that it will work on its own?
Dec 2, 2009 at 11:34 PM
FIXITMR
  • 9,989 POSTS
have you tried googling saturn radiator fan controls/problem? i just did and there are several tips available. you can also search this saturn sl2 forum for previous similar problems and answers.
Jan 12, 2019 at 4:28 AM
