1996 Saturn SL2 Compressor Replacement procedure
1996 SATURN SL2
126,000 MILES • 4 CYL • FWD • AUTOMATIC
TSNYDER2475
I am a do it yourself person. I purchased a used compressor from junk yard and need guidance on how to remove compressor from the car.
Jun 9, 2009 at 9:13 AM
BLUELIGHTNIN6
  • 16,542 POSTS
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_520.jpg
Jun 9, 2009 at 1:14 PM
TSNYDER2475
Thank you for your quick response,I need to know if tensioner requires a special tool to loosen or can be moved with just a wrench or pry bar to loosen bellt.I know this seems petty but I have a short time schedule on the repair time and need to know as much as possible before I start.usually I go to a u-pull-it location and I learn by removal of trial and error on their vehicle, this time they had part already off so O did not have the luxury of experimentation on my side in this situation.Thank you again and I look forward to trying to make some sort of donation to you when it becomes affordable, right now I have been unemployed for a year and a half and it does not seem to get any better.I am attending a trade school to learn a new occupation.
Jun 10, 2009 at 12:03 AM
PLUS2COM
  • 27 POSTS
the tension er is a Metric nut, i believe its a 13mm , or 10mm socket its nothing special ..
Jun 18, 2009 at 12:56 PM
