1996 Saturn SL2 abs light on
1996 SATURN SL2
140,000 MILES • 4 CYL • 2WD • MANUAL
ASKYJAKE
hi, my abs light is on. new brakes put on and light still on and brake pedal is soft.
Jan 22, 2010 at 10:23 PM
BMRFIXIT
  • 19,053 POSTS
Check if hydraulic system is leaking
(lines ,fitting ,wheel cylinder ……..)
repair AS NEEDED and bleed the system
check for ABS codes
Jan 22, 2010 at 10:39 PM
