1996 Saturn SL2
136,000 MILES • 4 CYL • 2WD • AUTOMATIC
MYCAR#2
When i put it in reverse it slams hard but all the other gears are ok so wat could this be.
Sep 3, 2010 at 5:32 AM
SATURNTECH9
  • 30,868 POSTS
It sound's like a valve body problem do you have any code's?Also does it shift hard into any of the forward gear's?
Sep 3, 2010 at 5:46 AM
MYCAR#2
There is no codes and no its just in reverse all the foward shift good with no problems
Sep 3, 2010 at 9:32 AM
SATURNTECH9
  • 30,868 POSTS
Now it all depends on how good you are with tool's if your good with tool's and want to save some money then the next step would be to check the transmission min and max pressure's and remove the valve body and air check the clutches.
Sep 3, 2010 at 12:39 PM
MYCAR#2
Thas wat i was thinking and i got a pressure tester but how do i check all that
Sep 7, 2010 at 4:16 AM
SATURNTECH9
  • 30,868 POSTS
So you have a transmission pressure tester with all the adapters?If so what pressure does the gauge go up too?
Sep 7, 2010 at 6:50 AM
