1996 Saturn SL2
CARISSA_SM
Engine Performance problem
1996 Saturn SL2 Manual
My car has a hard time starting. I usually need to put the clutch and accelerator in to get it started. I just changed the plugs and wires and have no codes. An help would be great!
Jul 23, 2010 at 2:23 PM
SATURNTECH9
  • 30,868 POSTS
You have to push the clutch in to engage the starter that's normal.So what your saying is you have to have your gas pedal all the way to floor to start it?When it start's does it blow out a lot of black smoke?
Jul 23, 2010 at 4:00 PM
CARISSA_SM
Yes I have to put the gas pedal down to start it. No black smoke, but a lot of white smoke.
Jul 23, 2010 at 4:14 PM
SATURNTECH9
  • 30,868 POSTS
Sound like a bad coolant temp sensor make sure you get a brass tipped one the plastic tipped ones crack.Also make sure you inspect the connector going to it if it's corroded then replace the connector too.The sensor's are only 10.
Jul 23, 2010 at 5:28 PM
