1995 Saturn SL2 Window doesn't roll down all the way...
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
PSL2
  • 41 POSTS
My driver side window doesn't want to roll down all the way. It goes down about 30% of the way down but stops. I hear a clicking noise. So if anyone could help please let me know thanks.
Jan 4, 2010 at 5:43 AM
SATURNTECH9
  • 30,869 POSTS
sounds like ur window regulator went bad try pushing the window with ur hand while operating ur switch down and see if it goes down a little more.u ethier have a bad regulator or the window is binding most likely u have a bad regulator u might be able to replace just the motor if ur regulator gear isnt worn out.let know how it goes and what u find.
Jan 4, 2010 at 9:51 AM
PSL2
  • 41 POSTS
I could push the window down but I have to pull it up to get it working again. Also I got a whole door at the junk yard to see if I could just replace the door and it would he fixed but it does the same thing in almost the same place... Please help thanks
Jan 4, 2010 at 10:55 AM
SATURNTECH9
  • 30,869 POSTS
Wow replacing the door that's alot work compared to a window regulator.u could just have a bad window regulator in that junk yard door very possible.if u can hear the window regulator clicking in the door u know it's getting power so now u just have to figure out if the window is binding or u have a regulator.u have to remove the outter door skin and unbolt the window and see if it slides up and down freely the window nuts takes a special socket made By OTC u can try to get the nuts off without it nut I doubt u will be able too.u can probably find one online let me know if u can find the socket or what u figure out.
Jan 4, 2010 at 11:31 AM
PSL2
  • 41 POSTS
Yeah it is alot of work cause I figured it would be cheaper and easier to do it that way but I found out that it's hard. Well i took out the outer and inside skin and it clicks as I roll it down but stays at that same spot. What does the regulator look like. Also could it possibly be a window control module problem? Thanks
Jan 4, 2010 at 11:54 AM
PSL2
  • 41 POSTS
Nevermind I know what the regulator is. Btw I only paid 25 bucks for the door...
Jan 4, 2010 at 12:03 PM
PSL2
  • 41 POSTS
What kind of socket? Could i see a pic or get a website?
Jan 4, 2010 at 3:42 PM
PSL2
  • 41 POSTS
It doesn't click anymore as I roll it down soo could it be the motor and the regulator?
Jan 5, 2010 at 4:12 AM
SATURNTECH9
  • 30,869 POSTS
There's a website that sells OTC Saturn window sockets go to www.etoolcart.com there's a specialty tools section click Saturn tools and u will see it Theres no window module on that car.make sure u have power and ground to the motor and if doesn't move anymore then u probably have a bad motor but make sure ur regulator gear isn't worn out otherwise u have to replace the the whole thing.once u get that window loose then u can see if it's binding and go from there.let me know what u find and how It goes.
Jan 5, 2010 at 11:37 AM
PSL2
  • 41 POSTS
Are there any stores that sell that tool and i will let you know thanks. Also how could I tell if it's binding or not?
Jan 5, 2010 at 11:45 AM
PSL2
  • 41 POSTS
What are some of the signs of a bad regulator? Cause the other door looks like the regulator is good. But I guess looks can be deceiving. Thanks
Jan 5, 2010 at 11:54 AM
SATURNTECH9
  • 30,869 POSTS
If u can find a store that sells OTC tools the number is OTC7827 I don't know of one where u live u could call around and maybe find one that does now that u have the number for it.as far as see if its binding like I said before if unbolt the window u can then move the glass up and down with the glass even and see if it moves freely let me know what u find.
Jan 5, 2010 at 11:59 AM
PSL2
  • 41 POSTS
Thanks I got it working finally!
Jan 19, 2010 at 4:28 PM
SATURNTECH9
  • 30,869 POSTS
Glad to hear u got the window going congrats.if u ever have any other questions feel free to post them.
Jan 20, 2010 at 2:29 AM
