1995 Saturn SL2 why water is leaking in
HENCAR
Air Conditioning problem
1995 Saturn SL2 4 cyl Front Wheel Drive Manual
why is the floor on passenger side wet when a/c is on? the heater does not work becus of leak, so it has been by-passed. thanks for your time.
Jun 20, 2010 at 7:52 AM
SATURNTECH9
  • 30,869 POSTS
Sound's like your a/c drain is clogged up and not draining.In your engine compartment on your firewall down low about in the middle of it you will see a hole get a coat hanger and use that to clean it out make sure the car is parked somewhere you don't mind getting wet there is probably atleast a gallon of water trapped in there.Let me know how it goes.
Jun 20, 2010 at 8:41 AM
