1995 Saturn SL2 Question on the radio...
15,200 MILES • 4 CYL • 2WD • AUTOMATIC
PSL2
  • 41 POSTS
I would like to get an oem radio with a cd and cassette player. Which Saturn and year is compatible with mine? Thanks in advance! Btw I'll probably get it from the junk yard.
Thanks!
Jun 10, 2010 at 6:36 AM
SATURNTECH9
  • 30,869 POSTS
I could be wrong but i don't ever remember the S model saturn having a cd/cassette i know the L model did but don't remember the S model having it.So look's like your out of luck on that one.I know jensen radio's made a cd/cassette that fit right into the 91-94 S model saturn's they sold them at walmart.In 1995 they changed the dash and radio like the one in your's so that one would't fit.I would check with jensen though they might make one that fit's that newer dash.They also sell pig tail connector's so you don't have to cut into the factory harness to put in a aftermarket radio.Also they have install kit's so the aftermarket radio's fit in the saturn's pretty nice.
Jun 10, 2010 at 7:23 AM
PSL2
  • 41 POSTS
I could have been wrong as well. Do you know if there is a cd one for the S?
Thanks!
Jun 10, 2010 at 7:29 AM
SATURNTECH9
  • 30,869 POSTS
Yes they made a cd player for the S model i have one in 1999 SL2.If you don't have a cassette eq in your car now you will want to get the speaker's that are in the car with your cd.The cd and cassette eq radio's have amplifer's and use differnt oem speaker's.So if you use the old speaker's with ethier radio you blow the speaker's.If the oem speaker's in your car say 10 ohm on the magnet then you can't use them with the cd player.They won't match the radio won't sound right and you will blow them.You can use a 1995-1999 radio and speaker's in that car.
Jun 10, 2010 at 7:50 AM
PSL2
  • 41 POSTS
Cool, thanks! I was thinking about getting new speakers anyways. Do you recommend any?
Thanks!
Jun 10, 2010 at 10:25 AM
SATURNTECH9
  • 30,869 POSTS
I like the sony explodes they sound good and are easy to install on the saturn's.
Jun 10, 2010 at 10:33 AM
PSL2
  • 41 POSTS
Thanks for all the help!!
Jun 10, 2010 at 11:02 AM
