1995 Saturn SL2 Motor mount
154,000 MILES • 4 CYL • 2WD • AUTOMATIC
PSL2
  • 41 POSTS
I replaced my top motor mount on my car and it still shakes. Is there another motor mount somewhere else?
Thanks
Jul 9, 2010 at 5:03 PM
SATURNTECH9
  • 30,869 POSTS
Does it shake at idle in gear or out of gear with your foot on the brake?
Jul 10, 2010 at 5:30 AM
PSL2
  • 41 POSTS
Hmmm that's a good question. I believe it shakes while idling in gear. I have to verify this though.
Thanks
Jul 10, 2010 at 5:57 AM
SATURNTECH9
  • 30,869 POSTS
If it's in gear then your looking at a colasped lower transmission mount at the bottom of your transmission.
Jul 10, 2010 at 6:42 AM
PSL2
  • 41 POSTS
Ok I'll look into it; however, I took off my wheel to do some work on my brakes and I noticed a mount on the passenger side. Bottom of the motor. Could that also effect this?
Jul 10, 2010 at 11:08 AM
SATURNTECH9
  • 30,869 POSTS
Unless it's oil soaked or you can see that the round rubber end of it shrank and it's moving around then I wouldn't replace it.
Jul 10, 2010 at 11:51 AM
