1995 Saturn SL2 hydralic clutch
100,000 MILES • 4 CYL • FWD • MANUAL
ERVINBRAT
replaced clutch with kit and now hydralic not working, so i bought a new sealed system and install now slave cylinder works but i only get 3/8 traval and i need a1/2 , took clutch kit back out and replaced the hole kit with another clutch , pressure plate and throw-out bearing and still do not engage but 3/8. what is going on. i dont have a bent clutch plate.
May 7, 2010 at 12:49 PM
PLUS2COM
  • 27 POSTS
Have you Checked the Cable linkage leading to and from the clutch pedal to see if its adjusted properly .. also check to see if its binding up on the firewall were the cable passes through . hope this helps
May 21, 2010 at 3:58 AM
