1995 Saturn SL2 HELP
SGIFFORD06
1995 Saturn SL2 4 cyl Two Wheel Drive Automatic
Recently my car has started choking randomly then dying. It turns right back on however it makes it dangerous driving to work. i've replaced the fuel filter cleaned the throttobody and tried fuel injecter cleaner. I think it might be the fuel pump relay but im unsure. Can you help?
Apr 30, 2010 at 2:17 PM
BLUELIGHTNIN6
  • 16,542 POSTS
the relay is relatively easy to replace and inexpensive. if you believe its a fuel issue then that is the best place to start. is the check engine light coming on ?
Apr 30, 2010 at 2:25 PM
SGIFFORD06
most of the time no if it has a longer stall and i have to wait a few second the check engine light will pop on for maybe a minute then go out and im unable to get a code reading.
Apr 30, 2010 at 4:13 PM
