This SL2 dies after running within a few mins. It has had 3 new fuel pumps replaced. A new fuel filter has been installed. After installing the first pump the car ran for almost 10 mins then died and loss all fuel pressure to only about 9 psi. The second pump did the same with great fuel pressure to start out, then only 9 afterwards. before installing the third. The fuel tank was cleaned out . The fuel lines were blown out using an air compressor. Installed the third pump and the same thing happened. Checked voltage going to the pump and all wires were getting correct voltage. checked wires for any damage or shortage and found none. I know there is alot of miles on the car, but could this really stop the car from running? Need Help HERE! PLEASE!
Apr 15, 2009 at 9:47 AM
