My car is overheating and I just replaced the thermostat. I think it could be the fan. How could I check if its good or not. Thanks
Dec 19, 2009 at 11:19 AM
BLUELIGHTNIN6
✓Experienced Mechanic
turn the A/C to full blast and the cooling fan should come on automatically. if you don't have A/C then you will have to supply direct 12v to the fan to see if it comes on.
Dec 19, 2009 at 2:18 PM
PSL2
MEMBER
I turned on the ac and the fan doesn't turn on. Btw I charged my ac. I am just wandering if it's a connector or the fan. How could I tell?
Dec 19, 2009 at 2:43 PM
BLUELIGHTNIN6
first check the fuse. if its OK then check the cooling fan relay(s).
Dec 19, 2009 at 3:44 PM
PSL2
MEMBER
Fuse is good where is the relay??
Dec 19, 2009 at 3:46 PM
BLUELIGHTNIN6
your cooling fan relay is in the engine compartment fuse / relay block.
Dec 20, 2009 at 5:00 AM
PSL2
MEMBER
O I'll look for the relay. How would I check if it's good?
