1995 Saturn SL2 Brake and Reverse Lights on trunk not worki
CHELSEEGIBSON
Electrical problem
1995 Saturn SL2
I have a 1995 Saturn SL2 and the other night a wire harness in the trunk came unplugged while loading some stuff. The brake and reverse lights (on the trunk) don't work, but I couldn't find where to plug it back in. I looked all through out the trunk and over the internet and can't find where it's supposed to plug in to. Please help!
Aug 28, 2009 at 8:50 AM
DLWSR300
You've got to take your torx screwdriver and remove the tail light lens. You'll the three sockets' wires joined by a common plug. There's a single fat wire coming out of the fender with a plug. The sockets' plug and the fender's socket should be joined.
If you've been driving the car with the sockets unplugged for a while now, you might need a new tail light socket assembly. Water gets in there and corrodes the connections.
Dec 21, 2010 at 1:15 PM
DLWSR300
also try checking on the saturnfans.com. It's got a couple of DIY experts in there.
Dec 21, 2010 at 1:19 PM
SATURNTECH9
  • 30,869 POSTS
Look behind the carpet on the left side of of the trunk it should be there.
Oct 17, 2012 at 9:08 PM
