the abs & brake light are on, what does this mean?
Feb 13, 2010 at 1:14 AM
SATURNTECH9
✓Experienced Mechanic
It means u have to check ur brake fluid level to see if it's above the seam of ur master cyclinder.also u have to go some where that they can read ur abs codes because there is a problem with ur abs.when u get the codes let me know what they are and I can help u further.
