1995 Saturn SL2
170,000 MILES • 4 CYL • FWD • AUTOMATIC
DAB18GAY
i changed the safety neutral switch and now my car will not change gears on it own when i get up to 35 it will stall like it is in neutral
May 21, 2010 at 6:27 PM
SATURNTECH9
  • 30,868 POSTS
[quote:bc11a6c301="dab18gay"]Transmission problem
1995 Saturn SL2 4 cyl Front Wheel Drive Automatic 170000 miles
i changed the safety neutral switch and now my car will not change gears on it own when i get up to 35 it will stall like it is in neutral[/quote:bc11a6c301]
How did your car shift before you changed the selector switch?Why did you change it?Did you adjust it with a ohms when you changed it?Let me know.
May 22, 2010 at 11:41 AM
DAB18GAY
i changed it when i was having problem with my car not wanting to start. and not i did not adjust it with ohms . where do adjust it at
May 23, 2010 at 10:08 AM
SATURNTECH9
  • 30,868 POSTS
https://images.2carpros.com/forum/automotive_pictures/416332_1995_sl2_selector_switch_adjustment_1.jpg
https://images.2carpros.com/forum/automotive_pictures/416332_1995_sl2_selector_switch_adjustment_picture_1.jpg
Here's all the information you need to adjust your switch.Let me know if you have anymore problems and need some more help.
May 23, 2010 at 3:45 PM
