HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Saturn
SL2
Drivetrain
Transmission
Symptoms
Not Shifting
1994 Saturn SL2 what could be done to fix
CODFISH25
MEMBER
1994 SATURN SL2
4 CYL
2WD
AUTOMATIC
150,000 MILES
Car will not shift unless you let off gas
Monday, August 16th, 2010 AT 12:17 PM
SATURNTECH9
MECHANIC
So does the car have plenty of power?Do you have any code's. Usually when you have to let off the gas to get it to shift you have a problem with the cat being plugged or with the transmission.
SPONSORED LINKS
Monday, August 16th, 2010 AT 12:22 PM
Please
login
or
register
to post a reply.
Related Transmission Not Shifting Content
1994 Saturn Sl2 Will Not Shift Gear
I Believe This Is A Transmission Problem But I Am Not Sure. Your Help Is Greatly Appreciated. My Wife Borrowed Her Sisters Car To Take A...
Asked by
SRQMIKE
1 ANSWER
1994
SATURN SL2
1994 Saturn Sl2 Transmission/cooling Problems
My 94 Sl2 Has A Couple Problems That I Know Of. First Of All, There Is A Leak That Comes In On The Passenger Floor. Also, I Can't Keep...
Asked by
grocco_99
1 ANSWER
1994
SATURN SL2
Trouble Code Is P0734 - A/t Won't Shift Into Last Gear
In A Nutshell. 1998 Saturn Sl2 Auto Tranny Does Not Shift Into Overdrive (last Gear). No Other Problems With Tranny At All. Shifts Perfect...
Asked by
jakecrawford2
1998
SATURN SL2
Auto Trans Downshifts
When Vehicle Warms Up And Goes Through The Shifting Sequence The Tranny Will Downshift At About 40 Mph To A Lower Gear And The Rpm's Hit...
Asked by
redwings36
2 IMAGES
1995
SATURN SL2
1993 Saturn Sl2 Tranmission Might Not Be Shifting
I've Got A '93 Saturn Sl2 With About 150,000 Miles On It. Recently Its Been Doing This Thing Where After I"ve Been Driving For A While, I'...
Asked by
qgabe101
1993
SATURN SL2
VIEW MORE
SPONSORED LINKS
Transmission Turbine Sensor Replacement
Transmission Speed Sensor Replacement Honda
Pilot Bearing Replacement
Online car repair manuals
