1994 Saturn SL2 water pump
1994 SATURN SL2
254,000 MILES • 4 CYL • FWD • MANUAL
LLHUBBARD
how to remove and replace water pump
Jun 16, 2009 at 12:16 PM
BMRFIXIT
  • 19,053 POSTS
1.9L 4 cyl vins (7,9)
WATER PUMP
Removal & Installation
Drain coolant. Remove accessory drive belt. Raise and support vehicle. Remove right front wheel and splash shield. Remove water pump pulley. Remove water pump bolts and pump.
Remove old gasket material from block.
To install, reverse removal procedure using NEW gasket. Tighten bolts evenly to specification. Fill cooling system and check for leaks.
Jun 16, 2009 at 12:44 PM
