1994 Saturn SL2 no clutch pedal pressure
152,000 MILES • 4 CYL • FWD • MANUAL
AARONWETSBROOK
i just replaced my clutch disc, pressure plate, and throw bearing. when i put everything back together i had no pressure on my clutch pedal. i replaced master cylinder, slave cylinder and lines (and bled the lines) but the problem still won't go away. i've run out of soloutions, any ideas?
Apr 24, 2009 at 4:39 PM
  • 75,988 POSTS
No leakage -Bleed it again if it continues double check the M/C and the slave
Apr 24, 2009 at 4:52 PM
