1994 Saturn SL2 Just wondering.
GAZHAULR
  • 1994 SATURN SL2
Engine Mechanical problem
1994 Saturn SL2 4 cyl Front Wheel Drive Automatic excess miles
Ok.I got a 94 SL2 that I refuse to depart with. This thing has well in excess of 325,000 miles on it but it is a good solid car. Right @ 3 years ago the original engine went down. #3 cylinder had only 60 lbs of compression when I checked. So.I found me a junkyard engine, slapped it in, and I'm up and running again.
This morning on the way into work, it lost power. So I pull into WalMart just look under the hood (like thats gonna fix it). Then I head back home to pull a compression check. Guess what. It's the same #3 cylinder as the original engine and it has only 60 Lbs.
My question is. Is this a coincidence or is it "The Saturn Conspiracy". Saturn Rules.
Friday, January 8th, 2010 AT 9:23 AM
SATURNTECH9
  • 30,869 POSTS
When u get a low cyclinder like that #3 is common or #2 the two inner ones get the most heat. Usually its the valves causing the low compression from what I have seen especially when it happens from one moment to the next like that. Let me know how it goes good luck with ur project.
Friday, January 8th, 2010 AT 10:03 AM
