1994 Saturn SL2 Engine Fan
165,000 MILES • 4 CYL • 2WD • MANUAL
TDFREASIER
The engine fan on my saturn does not come on when the car gets hot. I have checked all the fuses and the relay. I checked the fan and I replaced the coolant temp sensor. I also check the voltage at the harness and it was 5.02. I am stumped I don't know what else to try. The fan does come on when the a/c is on. Can anyone help?
Jan 2, 2010 at 7:44 AM
SATURNTECH9
  • 30,869 POSTS
U should atleast have 12 volts at ur fan motor.which sensor did u change the one with two wires or the one with one wire going to it?let me know.
Jan 12, 2019 at 4:26 AM
TDFREASIER
the one with 2 wires going to it
SATURNTECH9
  • 30,869 POSTS
So how high does ur temp gauge go?the fan doesn't come on till 3/4 or sometimes the tip of the red on the older models like urs when gauges get older.u could even have a bad gauge or gauge sensor.do u have a temp gun there cheap now and can use them for alot of differnt things.
TDFREASIER
I changed out the sender sensor and let the car get up to about 3/4 and the fan came on. Thanks for all the help.
