1993 Saturn SL2 speedometer-odometer
250,000 MILES • 4 CYL • FWD • MANUAL
BIOMEDBOB
The speedometer works fine, but the odometer and tachometer do not.
fuse? wiring? sensor?
Jan 18, 2010 at 6:11 AM
SATURNTECH9
  • 30,869 POSTS
well on the odometer the little plastic gear is probably broken drives it very common.my sisters 93 her odometer went out put a used one in it then two weeks later that one went out too.they sell the gear but u have to take the whole cluster to replace it.unless ur good at fixing things i wouldnt try it.as far as ur tach have u tried smacking ur dash while its running to see if the tach moves?if that doesnt work u would have to trace the wires to ur tach to make sure there good and if they were then would have a bad tach but u cant just get the tach ur car comes as a whole cluster assembley.let me know what u find.
Jan 19, 2010 at 4:56 AM
