1993 Saturn SL2 service engine soon light
DWRAGER
  • 1993 SATURN SL2
  • 4 CYL
  • FWD
  • MANUAL
  • 180,000 MILES
I have a 1993 Saturn SL2. The vehicle had been running fine with no issues. The water pump went out and was replaced. To access the pump, we moved the
AC unit out of the way, replaced the pump and checked for leaks. Everything was fine with the exception that now the 'service engine soon light is on. Any ideas what may have caused this?
Monday, July 19th, 2010 AT 7:58 PM
Check engine light:
Have the computer scanned for code/s-you have a problem within the engine management system that caused the CEL to turn on-This is your starting point of diagnosis, finding out what's going on.
Monday, July 19th, 2010 AT 8:04 PM
