1993 Saturn SL2 please help
SAMANTHALEE18
1993 Saturn SL2 4 cyl Front Wheel Drive Automatic
I have had my saturn for about 3 years and didnt have a problem until this winter. It all started by haveing starting problems then when i took it anywhere it seemed as though it had water in the gas after my dad replaced the fuel filter and starter now it seems like the car will only start on days that the sun shines on the hood but it sometimes still has the boging problem around 1 rpm and it acts as though there is water in the gas but i know there is not also after it does start it will run fine until i shut it off and let it set for any longer than 30 minutes after that it will not start until the next day if the sun was shineing on the hood me and my dad have no idea about what could be wrong with the car it has been this way since December and i realy need it fixed soon please help if you have any ideas please let me know
P.S. we hooked up new spark plugs and wires.
there is not gas comeing out of the injecture
Mar 24, 2010 at 11:46 AM
BMRFIXIT
  • 19,053 POSTS
start by checking it for tune up
check and replace ignition wires
Mar 24, 2010 at 11:54 AM
