Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Saturn
SL2
Fuel System
Fuel Pump
Fuel Pressure
1993 Saturn SL2 Fuel pressure
1993 SATURN SL2
130,000 MILES • 4 CYL • 2WD • AUTOMATIC
RPMCCAS
MEMBER
1 POST
How much fuel pressure should a 93 Saturn have? Mine primes to 45 psi, then reduces to 35 while running.
Feb 17, 2010 at 11:51 AM
Experienced Mechanic
FUEL PRESSURE SPECIFICATIONS
FUEL SYSTEM:
SOHC: Pressure at idle and 3,000 RPM.(26-31 psi)
DOHC: Pressure (Key ON/Engine OFF or Engine running/Wide open throttle: (38-44 psi)
DOHC: Presure at idle, 60 kPa vacuum: (31-36 psi)
Feb 17, 2010 at 12:04 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
