Transmission problem
1993 Saturn SL2 4 cyl Two Wheel Drive Manual
if your speedo cable breaks will it leak gear oil
Monday, March 29th, 2010 AT 7:41 PM
SATURNTECH9
MECHANIC
U dont have a speedo cable and u should have transmission fluid in ur transmission not gear oil. So where is ur leak at?
SPONSORED LINKS
Monday, March 29th, 2010 AT 7:46 PM
JIMPAGE38
MEMBER
U dont have a speedo cable and u should have transmission fluid in ur transmission not gear oil. So where is ur leak at?[/Quote:7338b82266]between tranny and motor it felt like a small pop then the speedo started to seem slower then im go ing then I noticed fluid leaking
Monday, March 29th, 2010 AT 7:52 PM
SATURNTECH9
MECHANIC
If u give more detail about where the leak is I can help u better of where its comming from. Let me know.
