1992 Saturn SL2 Transmission grinds sometimes
180,000 MILES • 4 CYL • FWD • MANUAL
HAYNER3
Okay so recently the clutch went out and it was parked for about a month until i couls replace it. Qhen i finally got to replacing it there was a hole the size of about two quarters in the bell housing of the transmission around where the shift fork and throw out bearing sits. So i went and pulled the bell housing from another car and got it all back together. I replaced the clutch, and reinstalled the transmission, but now the it doent shift right. 1st and 2nd gear work perfectly fine, but when i shift into 3rd, 4th or 5th it grinds and doesnt go into gear. Reverse works fine. I recently replaced the master/ slave cylinder assembly also as it was damaged in removal of the transmission. Im thinking its gotta be in the linkage somewhere any suggestion?? Anything??
Sep 26, 2010 at 10:46 AM
SATURNTECH9
  • 30,869 POSTS
My question is what caused the the hole in the clutch housing?That's what i would be worried about.Also were you driving the car around with a hole in the transmission?Sound's like you were.Let me know.
Sep 26, 2010 at 1:25 PM
