1992 Saturn SL2 bleed rear caliper ABS
175,000 MILES • 4 CYL • FWD • MANUAL
KENKERNODLE
Is there any way to do this without going to dealer?
Apr 8, 2010 at 6:15 PM
CARADIODOC
  • 34,414 POSTS
If you're doing normal brake repairs, you bleed the brakes like normal. It makes no difference if there is ABS on the car unless you let the system run out of fluid.
caradiodoc
Apr 8, 2010 at 6:51 PM
