2002 Saturn SL1 Window Washer Pump
2002 SATURN SL1
POKITTS71
Electrical problem
2002 Saturn SL1 6 cyl Front Wheel Drive Automatic
How do I determine if my window washer pump is working, I pull on the lever, and hear a sound like a moter trying to work, but I get nothing from the spray nozels, I have plenty of washer fluid, What is the next step. How do I replace a bad pump?
Jan 14, 2009 at 3:13 PM
BLUELIGHTNIN6
  • 16,542 POSTS
The first thing to do is to clear lines of any debris that may be blocking fluid from flowing. After this, check your fuses to ensure they are not blown. Fuse will be a 25 amp.
Thanks for using 2CarPros.com!
Jan 14, 2009 at 5:46 PM
